Affect Volume Density by Geometry Distance
Thanks for replying, I just whipped up a diagram on my phone (excuse the poor handwriting) but this is what I am trying to achieve. Let A be the volume I want to affect, and let B represent an object (either geometry or volume) placed close to A. I'm trying to do something like an attribute transfer but with volume density, in this order: copy density from B to A with a given distance threshold.
Edited by rhussain
Here's a way to do it using 2 volumes. The key is to pad the volume that you want to use for falloff by the distance over which density will be affected, otherwise when you sample outside the bounding box you get a distance to the bounding box itself plus the distance to it's center (I think). Be careful plugging in large objects as the volume resolution is set to By Size in order to account for changes in padding.
Another approach might be to convert all voxels to points with a density attribute, use a Ray Sop to get the minimum distance and then sample the points back to a volume. This would save the step of converting the affecting object into an SDF and might be beneficial if you have a very large distance relative to voxel size. Might.
densityFalloffFromGeo.hip
  • Like 2
  • 4 years later...
  • 3 years later...
On 1/5/2013 at 10:09 AM, anim said:
if you want to fade just by distance to points, you can sample pointcloud from within volume vop, therefore you will avoid converting collision object to volume
volume_fade_near_points.hipnc
Hi, I can't find any help document about old for loop VOP. Can you kindly update your hip? Or please give me some link for tips?
