Houdini 12 Pyro cache
mohit
Hi ,
So I have few queries related to the cache process in Houdini 12.
# How can I take out Pyro cache in Houdini?
#Can I use the cache in other file (same settings) or same file saved with different name,If yes then How?
# What are the steps do I need to follow to observe my Pyro cache working,so far I tried using the cache file while turning on cache option and found out that it was not working and starts calculating again.
If you'd like to cache your simulation ---> create geometry sop ---> add Dop Import Field node (Dop Newtwork - is string where you should add path to your Dop newtwork , Default Object - is an object which contain all fields in you Pyro sim by default it has a name - Smokeobject1(if you will set sim manually ) or Pyro if you will create sim from the shelf ) --- >after put + button and in the Field write the name of your Field (density , vel , heat , temperature , etc) --- > after put Rop output driver and write your fields to bgeo format --- > after load it with the File Sop node. :) Think it will help you.
http://www.sidefx.com/docs/houdini12.1/nodes/sop/dopimportfield
http://www.sidefx.com/docs/houdini12.1/nodes/dop/rop_dop
http://www.sidefx.com/docs/houdini12.1/nodes/sop/file
