maple Posted March 20, 2013 Share Posted March 20, 2013 Hello, everyone. I need to make a hole in the clouds now, which is composed of the cloud formations, and the camera needs to pass through the hole, coming out of the cave, but I tried a variety of methods, can make out cloud effect, but not a bit of depth, though the cave is very long, now I would like to ask you, who have what good way to achieve such an effect. Quote Link to comment Share on other sites More sharing options...
lukeiamyourfather Posted March 20, 2013 Share Posted March 20, 2013 What specifically is the issue you're running into? What have you tried that didn't work? Quote Link to comment Share on other sites More sharing options...
maple Posted March 21, 2013 Author Share Posted March 21, 2013 (edited) What specifically is the issue you're running into? What have you tried that didn't work? http://forums.odforc...iser#entry84124Hi,lukeiamyourfather,thank you.I am using the node in the links above,thanks them very much.I need to make it look more depth,but I don't know how should I do. test.rar Edited March 21, 2013 by maple Quote Link to comment Share on other sites More sharing options...
mangi Posted March 21, 2013 Share Posted March 21, 2013 Hi Maple. not to sure if this is what your after mangi cloud_test_v03_ani.hip depth.mov Quote Link to comment Share on other sites More sharing options...
maple Posted March 21, 2013 Author Share Posted March 21, 2013 Hi Maple. not to sure if this is what your after mangi Hi,mangi.Thank you very much!But the effect is not obvious, and there are some stretch in front of the lens, this basically is to let the cloud cave looks very depth, make the hole seems very far, perhaps this should work harder on the rendering, but I am a novice, a lot of things can't, have no good idea! But still thank you very much! Quote Link to comment Share on other sites More sharing options...
mangi Posted March 21, 2013 Share Posted March 21, 2013 okay maple It,s actually a bit hard to see what your after. Maybe if you find some references , and show what your after could make a big difference. Well atleast when you get your ideas clear, put up your test so we can see it okay Cheers Mangi Quote Link to comment Share on other sites More sharing options...
lukeiamyourfather Posted March 21, 2013 Share Posted March 21, 2013 The technical methods are good in the scene that I downloaded. It's a matter of making the volume structure longer and adding more protrusions to get the same feel. Using a shorter focal length will make it feel longer, more like the concept painting in the original post. Quote Link to comment Share on other sites More sharing options...
