Why we have velocity value in voppop?
Hi
I'm a Houdini beginner so apologies if I am wrong... It looks to me though like you're setting the particle's velocity to be the same as its position so on frame 1, y position is 0.1 and velocity is 0.1 so by frame 2 it has moved to 0.104167 in y and its velocity is set to the same value. This setup will cause the particle to accelerate upwards.
Hope that helps
velocity is in units per second so the formula is
P+v/fps
so as your P is 0.1
then v is 0.1 (per second)
so v per frame is 0.1/fps = in your case 0.1/24 ~= 0.004167
so P next frame will be 0.104167 etc
the formula is actually P + v*timestep
as usually you are not computing data only from frame to frame but a few times inbetween using oversampling
and the duration of this computing step in seconds is called timestep
so if you are computing it only once per frame it will be just 1/fps, therefore P + v/fps
but with oversampling its rather 1/fps/samples
EDIT: too late :)
Edited by anim
@Martin : Thank you for you support.
@Tomas : Thank you so much for your kindly teaching.
@Flipp : Really thank you so much.
All thanks.
Really I was confusing about fps.
I have calculated that P/(frame/fps).
So I had gotten wrong the value.
I am happy to understanding that. Good tutors and nice solve.
Have a great weekend.
Best,
Jamie
Edited by jungjaehwa
One more question.
Where can I find the formula in Houdini help documentation?
I can not find it out.
And then next step, I have studied that output P connect input acceleration in voppop.
I want to understand that there is a difference between velocity and acceleration.
Help me.
at the beginning of each timestep acceleration is 0 and gets accumulated as a result of different forces (or direct modification) and at the end of the timestep it is added to velocity for the next timestep
something like v = v + acc*timestep (or as Fillip mentioned timestep is called TimeInc in vops)
so if initial particle v is 0 and you have constant acceleration of 1 then in one second v reaches value 1 in 2 seconds 2 etc
