Pyro beat
luke046
Hello all,
I've been doing some CHOPs n pyro test lately. Combining audio with animations is quite an interesting field I think. Also been playing with the pyro shader for different looks, appreciate any thoughts for improvements. My machine is a 2010 macbook pro, so a bit limited. Here's a test with pyro and CHOPs:
And a older one with particles:
Cheers!
  • Like 2
  • 3 weeks later...
I’ve done some more CHOPs driven pyro, but with RBDs as well. Thought I share it here, and any ideas for improvements is highly appreciated (specially on pyro shading/comp in Nuke). Still rendering this on my laptop so a bit limited but trying to optimize for decent renders/time.
Fireballs
https://vimeo.com/67566626
Some pyro shading and mixing color test.
Painting
https://vimeo.com/67820300
Here I’ve done a similar example to this fumefx test: https://vimeo.com/65370346, but also from geometry. Maybe this could be useful for example to art direct a colourful smoke from a mood board or so.
Stones
https://vimeo.com/68041804
And here I use same technique as Painting but emitting from a cracked object. Also pushes the smoke with the velocity from RBD.
Rumble
With this one I thought would be interesting to use lyrics from a song with the counter and beat from CHOPs.
Heart
This is the latest one. Here I use one geometry to keep it a constant look, but a counter switches between RBD sims to generate different cracks on the beat. I also added debris pieces flying around with the velocity field.
Cheers!
Edited by luke046
Great work :),
I was wondering, is the animation dependent on just the amplitude/volume of the music, or also on the pitch?
I'm trying to set up some basics for visualizing audio now, but every time I change the pitch range, or change the pitch resolution,
I have to rename all my CHOP channels manually again.
Thanks man, glad you like it!
Here the animation are based on the amplitude off the two channels, and a counter with a threshold on the amplitude. Be interesting to take out even more sound attributes like the pitch, but I think in my case it can get a bit unclear if to much going on already.
Not familiar with that issue, but I try to have the final audio ready before I import to CHOPs. Maybe in your case you need to fix that in CHOPs though.
