newbee Posted July 6, 2013 Share Posted July 6, 2013 (edited) first of all.. let me mention that i am quite new to houdini what i want to know is if there is a particle create tool in houdini using which i can click and create multiple points or sketch multiple points in scene which i can then use to instance some objects on to Edited July 6, 2013 by newbee Quote Link to comment Share on other sites More sharing options...
Ankit Sinha Posted July 6, 2013 Share Posted July 6, 2013 (edited) few video tutorial that might help you 1) http://www.sidefx.co...2202&Itemid=132 2) http://vimeo.com/17309337 Edited July 6, 2013 by Ankit Sinha Quote Link to comment Share on other sites More sharing options...
newbee Posted July 6, 2013 Author Share Posted July 6, 2013 (edited) thanx i will look through these Edited July 6, 2013 by newbee Quote Link to comment Share on other sites More sharing options...
Ankit Sinha Posted July 6, 2013 Share Posted July 6, 2013 (edited) try clicking on view on vimeo link under it or just open vimeo.com and append /17309337 to it. u can also search it on google by typing "peter quint particle leaves on vimeo" Edited July 6, 2013 by Ankit Sinha Quote Link to comment Share on other sites More sharing options...
newbee Posted July 6, 2013 Author Share Posted July 6, 2013 (edited) thanx got that already i glanced through the videos, but couldnt find what i was looking for i dont want to generate points randomly on surface rather i wanted to "mouse click" to create points at desired locations there is a create emitter tool in shelf which lets me "mouse click" to create emitters but doesnt allow to create single particles at desired locations there is also the add sop but add sop only allows you to add one point at a specified location Edited July 6, 2013 by newbee Quote Link to comment Share on other sites More sharing options...
pbarua Posted July 6, 2013 Share Posted July 6, 2013 Here is the links to the videos by Houdini Guru Jeff Wagner. http://www.sidefx.com/index.php?option=com_content&task=view&id=2280&Itemid=363 http://www.sidefx.com/index.php?option=com_content&task=view&id=2281&Itemid=363 http://www.sidefx.com/index.php?option=com_content&task=view&id=2279&Itemid=363 Quote Link to comment Share on other sites More sharing options...
Erik_JE Posted July 6, 2013 Share Posted July 6, 2013 (edited) thanx got that already i glanced through the videos, but couldnt find what i was looking for i dont want to generate points randomly on surface rather i wanted to "mouse click" to create points at desired locations there is a create emitter tool in shelf which lets me "mouse click" to create emitters but doesnt allow to create single particles at desired locations there is also the add sop but add sop only allows you to add one point at a specified location You can specify the amount of points you want on the Add SOP. Then switch to point select mode and you can easily select them and move them around. Edited July 6, 2013 by Erik_JE 1 Quote Link to comment Share on other sites More sharing options...
newbee Posted July 6, 2013 Author Share Posted July 6, 2013 (edited) hey erik, moving multiple points around after creating them with add sop sounds like a lot of work would have been easier to just click and define where u want them to be positioned, especially since i want multiple points thanks Pradeep, as u said, i think i will stick to painting particles, as that seems to be the best thing to do Edited July 6, 2013 by newbee Quote Link to comment Share on other sites More sharing options...
anim Posted July 6, 2013 Share Posted July 6, 2013 just use Curve tool to manually place a lot of points interactively then you can append Add SOP to delete geometry but keep the points or maybe you don't have to depends on how you want to use them Quote Link to comment Share on other sites More sharing options...
newbee Posted July 7, 2013 Author Share Posted July 7, 2013 brilliant Grand Master ! Quote Link to comment Share on other sites More sharing options...
