ilmpixar Posted July 29, 2013 Share Posted July 29, 2013 One in the editing of the material, there are a lot of work to do, wait. . . RMaterial.otl 4 Quote Link to comment Share on other sites More sharing options...
ilmpixar Posted July 29, 2013 Author Share Posted July 29, 2013 preview 1 Quote Link to comment Share on other sites More sharing options...
lijunhong Posted July 29, 2013 Share Posted July 29, 2013 Thanks ,The OTL very cool ! Quote Link to comment Share on other sites More sharing options...
abvfx Posted July 29, 2013 Share Posted July 29, 2013 Looking forward picking this apart and learning from it. One thing i noticed in the screenshot is the Layers for you textures. I find there is no other way to add extra layers/textures? I tried using the Multiparm list but i cant get it to work. I wonder if anyone else has. There are workaround if your textures are sequential but you still chose whether to switch a texture on/off without "hard coding" it into the shader. Thanks for contributing. Quote Link to comment Share on other sites More sharing options...
ilmpixar Posted July 31, 2013 Author Share Posted July 31, 2013 Illuminance Aovs Quote Link to comment Share on other sites More sharing options...
ilmpixar Posted July 31, 2013 Author Share Posted July 31, 2013 simp_tex_layer simp_tex_lay.hip Quote Link to comment Share on other sites More sharing options...
Skybar Posted July 31, 2013 Share Posted July 31, 2013 Looks very nice. Will it support PBR as well or is it only for Micropoly? Quote Link to comment Share on other sites More sharing options...
ilmpixar Posted August 2, 2013 Author Share Posted August 2, 2013 it support PBR 1 Quote Link to comment Share on other sites More sharing options...
slayerk Posted August 8, 2013 Share Posted August 8, 2013 Great work Quote Link to comment Share on other sites More sharing options...
Guest mantragora Posted August 8, 2013 Share Posted August 8, 2013 Great work Great work on the hamster fur Quote Link to comment Share on other sites More sharing options...
abvfx Posted August 10, 2013 Share Posted August 10, 2013 simp_tex_layer Thank you for the example. However this is something i know . What i meant was how are you able to add texture Layers dynamically. Click on enable Layer 1 and a Layer 2 tab will appear. This is something i have tried to do for a while but have not succeeded. Thank you for your help. Quote Link to comment Share on other sites More sharing options...
abvfx Posted August 13, 2013 Share Posted August 13, 2013 Did some more diving, the ability to add extra texture layers is not dynamic (I didnt see them at first since they are invisible parameters and it was hard looking at the code, for some reason Houdini got really sluggish). There are 7 Layers predefined and by choosing to add an image will reveal the next one and so on. Does anyone know how to truly make this process fully dynamic giving the user control to add/remove texture layers. I know a way to automate via clever naming convention but the user will not have a way to switch them on/off as easy (which is needed when you want to save memory) Quote Link to comment Share on other sites More sharing options...
acorsei Posted August 29, 2013 Share Posted August 29, 2013 great work.... seems like I do something wrong or this is the expected behaviour but I don't have any image slot for displacement rgds Quote Link to comment Share on other sites More sharing options...
stevegh Posted October 1, 2013 Share Posted October 1, 2013 (edited) Looking forward picking this apart and learning from it. One thing i noticed in the screenshot is the Layers for you textures. I find there is no other way to add extra layers/textures? I tried using the Multiparm list but i cant get it to work. I wonder if anyone else has. There are workaround if your textures are sequential but you still chose whether to switch a texture on/off without "hard coding" it into the shader. Thanks for contributing. I believe I have succeeded in getting this to work at a fundamental level. Attached is a file that just has one material SHOP, and you'll notice it has an addNoise button. If you click the button, a turbulent noise node is added inside the shader, and the ui elements are promoted and linked to that node. Currently it's not hooked up to anything but this was my proof of concept as I really want to have a clean modular way of adding things with a single button press. This is all done via Python module of the digital asset. If you are good at coding please tear apart the code in here to make it better, as I will be adding stuff/making it better throughout the week. Ultimate goal here is to have a shader similar to how Max and V-Ray materials work, with maps created with the click of a button. Anyway, let me know what you think. -S layers1.hip layers.otl Edited October 1, 2013 by stevegh 2 Quote Link to comment Share on other sites More sharing options...
abvfx Posted October 3, 2013 Share Posted October 3, 2013 (edited) Hey there Stephen, Yep, this rocks. The only thing i would need to make sure i get right is the connections and promotions. I think for my uses i will create a custom texture map vop otl and use python to add them accordingly. I only had a brief look at the code, i imagine deletion and parameter cleanup is fairly straightforward? This is the way forward i think for my needs. Thanks a lot. I too will try to get a version going. I will look forward to your results. -andrew edit:// typo Edited October 3, 2013 by phrenzy84 Quote Link to comment Share on other sites More sharing options...
stevegh Posted October 3, 2013 Share Posted October 3, 2013 Hey Andrew, Yea I am currently breaking everything out to be flexible enough to handle any vop node, and I should have an example of this working with the mantra surface shader (hopefully) tomorrow. Have a look at the unifiednoise vop's scripts, along with the pyro2 module (C:\Program Files\Side Effects Software\Houdini 12.5.533\houdini\python2.6libs) for examples of how SESI is handling it currently. That's where I'm getting most of this from and while it is fairly straightforward it's taking me some time to get it right. Look forward to seeing where you end up! -S Quote Link to comment Share on other sites More sharing options...
abvfx Posted October 3, 2013 Share Posted October 3, 2013 Yea, im no python whizz so it might take me longer, but the custom texture vop wont take a minute. I already have a version in my shaders that is duplicated for each uv tile i require. I never thought to look into the pyro2 noise vop nodes, makes perfect sense, i remember how well it handled all those parm promotions. Quote Link to comment Share on other sites More sharing options...
stevegh Posted October 4, 2013 Share Posted October 4, 2013 (edited) So here is an update, I took the (almost) factory Mantra Surface shader and got this working. Right now if you plop down this node, go to the settings tab and hit add map buttons, it will go through and add buttons for a predefined set of parameters (shown at the very top of the python module script on the HDA). You can click to add a (for now still turbnoise) node, it'll populate with the added node parms and link them. You can also remove it which will obviously delete the node. Next up will be hooking these newly created nodes up, followed by creating an 'uber' map that will have a bunch of maps in it instead of just this turbnoise. Also not sure why the first parameter comes in as a string field instead of a dropdown but w/e. Still a good bit of clean-up to be done on the code as well but it's not terribly difficult to read at this point. My next post will probably be in a new thread as I feel we have hijacked this one - sorry! -S edit: I guess that first 'Signature' parameter isn't promote-able which is why it's coming in that way. Oh well it will be changed anyway. Also there is a stupid OGL env map error so just ignore that. mantraSurface_maps_01.otl Edited October 4, 2013 by stevegh Quote Link to comment Share on other sites More sharing options...
linuxbug Posted November 13, 2013 Share Posted November 13, 2013 great works thanks for share Quote Link to comment Share on other sites More sharing options...
