dt procedural rigs and controlling motion problem
Hi guys.
I followed the tutorial on procedural rigs and controlling motion by jonah hall but at lesson 10 im stuck... the thing he does gives houdini an error while going to chops.it says time independet or invalid input sop.
Even when i open his lesson file i got this same problem.
Using h12.5.376
Hi magi.
Thnx for your fast response.
I didnt know it was that different. It has something to do with write it to bgeo.(the movement of the robots) Cause if i skip that step it works but it takes alot of time because of caching. Was wondering why houdini doesnt work in version 12 with writed node files... do you know why or hpw to fix it on a different way? So i can still do this?
Hi Dennis,
I am on houdini 12.5.489
I open the file , exported the sim to bgeo
opended and the error is gone. ?
No to sure what you are really encountering.
Well here are some snap shots so we can all see it okay.
Mangi
post-2848-0-58021700-1376389475_thumb.jp
sim.mov
dennis.
Ya I did check the chops as well.
One thing I just notice when I opened the file with Houdini 12.5.458
get some issue "458.jpg"
Upgrade the Houdini. I am testing the file on
Houdini 12.5.489:
It may have to do with the versions
Mangi
post-2848-0-65083800-1376425662_thumb.jp
post-2848-0-95048400-1376425692_thumb.jp
  • 1 year later...
Hi there ,
I know this is an old topic but I am following the same tutorial (which is really well done) and i am running into a different error.
A bit later in the video he creates multiple channels in a chop-net and then references them in an attribute create node using
chop("../bug_chops/F/step")
which he later uses in a foreach loop to group certain points.
my problem is that the referencing does not work (houdini 14). i thought i made an error copying what he does so i opened his scene file and i have the same error so i assume its in the referencing.
i noticed that if i change
to
chop("../bug_chops/F/step$ID")
or to a specific channel aka:
chop("../bug_chops/F/step8")  (just picking one of the many chanels randomly)
i do get some data but its not the right one im fairly sure as the patterns do not co-relate with what they are meant to do.
Has the attribute create node or the way things are referenced from/to chopnets changed drastically?
i notice the node attributes look different from the ones in the video.
maybe somebody knows a work around to access the data from the chop net?
would be great if somebody knows whats up, would be a shame not being able to finish the tutorial
thanks in advance :)
  • 2 months later...
