daehuck Posted August 14, 2013 Share Posted August 14, 2013 Hi, guys I baked my dynamic scene into bgeo format But it's size is too big. 64mb per one bgeo. After bake, I read bgeo sequence in houdini and It doesn't fast at all. So can i get a more reduced size of it?? It's just a geometry. I don't know exactly why its size is too big. ANY COMMENTS WILL HELP FOR ME. Thanks Quote Link to comment Share on other sites More sharing options...
substep Posted August 14, 2013 Share Posted August 14, 2013 .bgeo.gz will zip them up for you. They take a little longer to read, but are quite a bit smaller. I use them, as I don't have giga flops of space Quote Link to comment Share on other sites More sharing options...
CtrlLoki Posted August 14, 2013 Share Posted August 14, 2013 you could try adding '.gz' to the end of your file path which will compression them. as in '.bgeo.gz' Quote Link to comment Share on other sites More sharing options...
mawi Posted August 14, 2013 Share Posted August 14, 2013 Delete all non needed attributes. Quote Link to comment Share on other sites More sharing options...
daehuck Posted August 15, 2013 Author Share Posted August 15, 2013 .bgeo.gz will zip them up for you. They take a little longer to read, but are quite a bit smaller. I use them, as I don't have giga flops of space thanks! But, why I want to make smaller is to read faster... Quote Link to comment Share on other sites More sharing options...
daehuck Posted August 15, 2013 Author Share Posted August 15, 2013 (edited) Delete all non needed attributes. I'll try. Thanks Edited August 15, 2013 by daehuck Quote Link to comment Share on other sites More sharing options...
yongbin Posted August 15, 2013 Share Posted August 15, 2013 if you are working in networks, file size is affecting your read speed. Quote Link to comment Share on other sites More sharing options...
dobin Posted August 16, 2013 Share Posted August 16, 2013 or you could save just the point representation of every piece read it back and copy stamp the pieces here is an example on the help card: http://www.sidefx.co...t/PointBasedRBD although the copy stamping could be very slow for large number of piece it's worth trying Quote Link to comment Share on other sites More sharing options...
mawi Posted August 16, 2013 Share Posted August 16, 2013 although the copy stamping could be very slow for large number of piece it's worth trying In that case I think the transform pieces SOP is faster. However there is no clue to what type of Geometry sim we are talking about... Quote Link to comment Share on other sites More sharing options...
