VDB meshing noised
polterizer
If you use a smooth sop, make sure you update the normals with a facet sop afterwards (post compute normals).
Otherwise there are ways to smooth the fields in the vdbsmoothsdf sop. You can use this and/or combine with more smoothing as needed. If you get into a situation where the splash looks good, but the flat surface looks too noisy you can blend based on the y position or speed of the points between a smoothed and non smoothed version with a simple vop.
thanks for your good answer, i must test that. anyway when deform NOT maybe doesnt need fix that as said me igor.
thanks!
