Flip water reaction
oslo
Hello guys. I have static pool with water and moving object from the deep
How to increase reaction between water and boat. I am used rigid velocity type for the boat because have very detail geometry. I dont want lose time for calculating collision sdf every frame.
Thanks
You could add some velocity to the boat before you send it to dops, maybe with a vopsop link the normals to vel with a curl noise in between. I guess its something like a simple pump.
If I misunderstood and thats not what you are after, you could play with the Velocity Scale and Surface Extrapolation under Collisions tab on your flipsolver. The first one simply scales your velocity, the other one can create more splashes if you lower it.
The Feedback Scale would make the boat react to the forces of the flip if it were dynamic, but its not so that won't do anything.
