kare Posted September 24, 2013 Share Posted September 24, 2013 Hi, I am currently struggling to create reverse rigid dynamic, something like this But instead of cubes, I have a voronoi fracture pieces. I found a way by using attractor but its not accurate and having some problems. Could anyone suggest a good idea to achieve this kind of effect. Quote Link to comment Share on other sites More sharing options...
JaydenDP Posted September 24, 2013 Share Posted September 24, 2013 I'm not 100% sure what you mean, but is it not just a case of simming forward, and reversing the cache? ie (100-$F) to play your sequence back in reverse from frame 100. Quote Link to comment Share on other sites More sharing options...
kare Posted September 24, 2013 Author Share Posted September 24, 2013 Unfortunately I can't use reverse animation. What I am working is to get that nice movement until rbd pieces reach its goal shape. Quote Link to comment Share on other sites More sharing options...
JuriBryan Posted September 24, 2013 Share Posted September 24, 2013 but that does not mean that you can't use a reverse animation. You can build the shape and release the pieces step by step with a glue network, and then reverse the cache. That way you still have the shape in the end, exactly the shape you build and you have the motion and the pieces at the beginning of your animation. since you can sculpt the velocity with forces to get he motion you want. Any other way would take to much time in R&D, at least try it. Cheers, Juri Quote Link to comment Share on other sites More sharing options...
gui Posted September 24, 2013 Share Posted September 24, 2013 Other way would be using sop solver to create a force for each particle to go for the original position, but one problem will be to orient them correctly... but using the reverse method will be much faster anyway... Quote Link to comment Share on other sites More sharing options...
rayman Posted September 26, 2013 Share Posted September 26, 2013 check this thread: Quote Link to comment Share on other sites More sharing options...
kare Posted September 27, 2013 Author Share Posted September 27, 2013 Thanks Rayman. This is what exactly I am looking for. Its helpful. Quote Link to comment Share on other sites More sharing options...
-nöm- Posted November 3, 2014 Share Posted November 3, 2014 (edited) The reverse-cache option sounds nice n promising. Most of all it sounds simple (And I believe it should look realistic as well). I'm trying to achieve a similar effect, but am wondering on how to fracture the main geometry into uniform-sized cubes. Any ideas? Edited November 3, 2014 by -nöm- Quote Link to comment Share on other sites More sharing options...
cubiccube Posted November 3, 2014 Share Posted November 3, 2014 Stack a couple Voronoi split sops with a grid piped into input 2. Quote Link to comment Share on other sites More sharing options...
-nöm- Posted November 3, 2014 Share Posted November 3, 2014 Thanks cubi, I shall give it a shot. At the moment I am achieving something similar by plugging in a "points from volume" SOP into the second input of a Voronoi Fracture SOP.Uniform distribution of points using specific values is providing me to break down my geometry into constant-sized cubes.However this would seem to work only on a symmetrical geometry.I'll try around for better alternatives. Quote Link to comment Share on other sites More sharing options...
gui Posted November 3, 2014 Share Posted November 3, 2014 In this case, I think the reverse will not give the best effect. The most simple way (I think) is using packed prims with a multisolver and use pop vops to control the pieces animation. Create a normalized vector (destinyP - P) to create a force pointing the destiny position. Once that is working, the next problem will be rotation. When you get that, ask and I will post a solution... Quote Link to comment Share on other sites More sharing options...
pbarua Posted November 3, 2014 Share Posted November 3, 2014 (edited) Here is a file from Tomas, check that out. http://forums.odforce.net/topic/16834-pops-glass-shatter-effect/?p=102788 Edited November 3, 2014 by Pradeep Barua Quote Link to comment Share on other sites More sharing options...
