DocWhite Posted October 23, 2013 Share Posted October 23, 2013 Hello everyone, What it happens is weird. When I try to simply render the view with the default Mantra renderer or another Mantra node I get this error. UT_NetPacket::write: No errormantra: Error writing data to image device[/CODE]Some people say that it is related to problems with the Firewall or the antivirus, I tried killing tasks and processes but I still get this error. However, if I re-start de program I can render perfectly all I want (sometimes, depending on the weather, yeah) and when a long time happens it outputs that error...Any suggestions? Thanks for your attention. Quote Link to comment Share on other sites More sharing options...
tmdag Posted October 23, 2013 Share Posted October 23, 2013 does it happen when you save render onto file as well or only with "ip"? Quote Link to comment Share on other sites More sharing options...
DocWhite Posted October 23, 2013 Author Share Posted October 23, 2013 does it happen when you save render onto file as well or only with "ip"? It does not happen when I render to an external file. Some people told me it could be MPlay.exe, it might not have enough privileges, or something like that, but I included an exception for it in my Firewall, it's complicated. Quote Link to comment Share on other sites More sharing options...
tmdag Posted October 23, 2013 Share Posted October 23, 2013 (edited) i haven't used windows for few years but afair, you might have to run houdini as administrator. You have to include all local connections for sesintd, houdini, mplay and all sidefx tools for proper work as it uses local connections for communication in-between programs. when you render to external file, mantra just creates file but when you render to IP, mantra opens up mplay and pushes image on the fly through the local connection so system have to give permission for that. Edited October 23, 2013 by tmdag 1 Quote Link to comment Share on other sites More sharing options...
DocWhite Posted October 23, 2013 Author Share Posted October 23, 2013 i haven't used windows for few years but afair, you might have to run houdini as administrator. You have to include all local connections for sesintd, houdini, mplay and all sidefx tools for proper work as it uses local connections for communication in-between programs. when you render to external file, mantra just creates file but when you render to IP, mantra opens up mplay and pushes image on the fly through the local connection so system have to give permission for that. I tried for 5 minutes and it works fine if I run it as administrator. I will keep you updated about future crashes. I am not sure if it is due to that because sometimes (when I don't run it as admin) it works and sometimes it does not, let's discard possibilities. Many thanks. Quote Link to comment Share on other sites More sharing options...
inigo Posted December 20, 2017 Share Posted December 20, 2017 Hi Artists!! I have some problems...The render view is generating scene and nothing happens... and mantra node tell me this. I have an apprentice license and i was rendering some chocolate last week with out any problems... Is the same problem but working in a mac and i dont know how to lunch as a administrator.. Quote Link to comment Share on other sites More sharing options...
lukeiamyourfather Posted December 21, 2017 Share Posted December 21, 2017 Please don't revive four year old threads. Quote Link to comment Share on other sites More sharing options...
sophia61 Posted August 20, 2024 Share Posted August 20, 2024 On 10/24/2013 at 2:43 AM, tmdag said: i haven't used windows for few years but afair, you might have to run houdini as administrator. You have to include all local connections for sesintd, houdini, mplay and all sidefx tools for proper work as it uses local connections for communication in-between programs. when you render to external file, mantra just creates file but when you render to IP, mantra opens up mplay and pushes image on the fly through the local connection so system have to give permission for that. On Windows, running Houdini as an administrator ensures proper functionality, especially for local connections between SESI tools like Houdini, mplay, and Mantra. This setup is crucial for seamless communication and rendering to external IP addresses or files. Quote Link to comment Share on other sites More sharing options...
