[bug #58157] H13 Crash on every OTL made in older versions of H
Guest mantragora
Guest mantragora
Like title says. Even simple OTL that wraps two fuseSOP's that create extended fuse, without any tricks, just some parameters exported to OTL. The same OTL I can import with "Install Digital Asset Library" but then when I try to use it in viewport it freezes it (can't move camera) till I press Enter.
Anyone else have similar problems?
Edited by mantragora
Guest mantragora
Hm, if you put it in otls folder it doesn't crash Houdini? If you call it in viewport it doesn't freeze Houdini? You are using some fake version of Houdini then :D
I installed using File > Install. I just tried calling from the viewport, and still good, but I couldn't select any points. I don't think I was in the point selection mode (no points shown). But pressing Enter, it placed it correctly.
I think your OTL is faulty :) Hope you are not using the OSX version because the windows version is solid :)
Guest mantragora
That's what I'm talking about. You can't select any points. Just Enter works. Have you tried to rotate camera?
Don't install it, put it in your otls folder and start houdini (v13 of course ;))
Guest mantragora
Yes, there is something else afoot, I think - during beta, Houdini 13 had no issues loading all manner of older OTLs. I'll try load your OTL later on today.
k, thanks
Guest mantragora
If you can't rotate camera that means your Houdini viewport freezes just like mine. In H12.5 you can rotate to select points on other side of the model.
Only if I put it in otls folder it crashes Houdini.
I definitely don't get a crash, but I do get the viewer getting put into a bad state when using the tool from the viewport.
For something like this, I think building a selector (hou.SopNodeType.addSelector) would probably be a better/more Houdini way to go. However, these things still seem to be crappy and unreliable. You could also look at adding the selecting logic in the node type's tool, rather than a specific OnCreated script.
Guest mantragora
ExtendedFuse is a SOP I made in H9. I haven't touched it since than. It worked till now. But yeah, when I tried to make this sop from scratch in H13 it also freezes the viewport once I add the code to it.
Those two are with Python, but I get also crash when I load tools that uses just hscript.
I'm reporting bug on viewport lock. It doesn't seem that anyone else have problem with crashing but I will mention this too.
Guest mantragora
Ok guys, try this:
Edit your houdini.env and set your HOUDINI_OTLSCAN_PATH = "$HFS/houdini/otls;" and add there also some custom path, for example "C:\Porn". Now move OTLs to this custom path and try to load Houdini. I get crash. If I comment this line and move my OTLs to my $HOME\houdini13.0\otls it loads OK. The same modification works correctly in H12.5.
H13 defers redraws while nodes are being created, flagged, and placed. This is why placing user interaction in the OnCreated script doesn't appear to work - all redraws are being held back. We really didn't expect it to be used that way.
It might be able to be worked around while keeping extraneous redraws to a minimum.
