Group Primatives by UV Tile
whodini
Hey guys, I'm looking into a way to group primitives based on their UV tile. I know how to do this in the viewport by switching to the UV view and selecting the faces of the geometry in the tile I want and clicking group in the shelf. However, I'm looking for a way to do this in vops or using an expression. I want a procedural way to do this. I don't know if the tiles are numbered or how I would go about doing this.
well if you are using vopsops you need your UVs to be point UVs (or convert them with an attribute promote) after that you can use something like a floor to to see in which tile the UVs are.
After that you could group the UVs by comparing the floor result with something. You could also use a modulo in between if you want to select every other UV tile for instance.
The same logic applies for using expressions something like floor($MAPU)>0, to select everything beyond the 0-1 range or floor($MAPU)%2==0 to select every other UV tile
for the V direction you can use $MAPV
Edited by acey195
Another way to do this is to use the Connectivity SOP with connectivity set to primitive, and "Use UV Connectivity" checked on. This will give you a unique class attribute for each connected set of uvs. Then just follow it up with an Partition SOP to make groups based on the class attribute.
  • Like 2
