convert sim velocity into vdb vector field
sanostol
is there a fast and efficient way to convert vel.x, vel.y, vel.z into a single vdb vector field
If I use vdb convert i get 3 individual fields stored in vdb, and as the vectors have different component values, the vdbs have different dimensions and transforms
martin
the chance is that the original velocity volumes are of different dimensions as well, just middle click prior to Convert VDB to see the dimensions
this may be caused by the fact that the default velocity sampling is set to Faces so go to your smoke or pyro object and change Initial Data/Velocity Sampling to Center and you should get the same dimensions for all 3 vel components
  • Like 2
