Interior Mapping Shader Help
EwanW
Hi!
Am having a problem trying to get my version of an interior mapping shader to work in Houdini. http://www.proun-game.com/Oogst3D/index.php?file=CODING/InteriorMapping/InteriorMapping.txt
The surface takes two inputs position(P) and a direction from camera(I).
It works fine in world position however I would like to translate the geometry so as best to fit my "windows" in different positions/rotations. When I do this at object level the shader sticks to the surface and works fine.
How do I replicate this effect when transforming the geometry at sop level?
Using a rest position instead of the world position works for translation, however, if I rotate the surface it warps. How do I translate my I vector so that it will work as it does at object level?
Any help is much appreciated! I am really lacking in maths knowledge here and would appreciate anyone weighing in with their thoughts.
Files attached Thanks!
post-10822-0-97611300-1386945872_thumb.j
interiorMapping.rarFetching info...
Edited by EwanW
you can create orient quaternion attribute(or any name you want) on the geo prior to any deformation then use AttribReorient SOP to reorient it to new deformed geometry
then just in shader orient your object space vector by inverse rotation of this orient attribute
here is the file
interiorMapping_v1_fix.hipFetching info...
  • Like 2
Amazing thanks very much :)
I think I understand the idea behind it roughly. Was trying to do something similar but in the very wrong way :) Do you have any recommended reading to understand this sort of thing? I can't really get my head around the idea of spaces and matrix transformations.
not really, I just got it slowly by practice, any kind of reading on matrices and spaces was too much for me before, maybe mostly because they try to explain all the equations while I just needed the concepts since Houdini does math for me, now it's much easier
but I would like to find some nice material on this topic as well
Edited by anim
  • 6 years later...
  On 3/1/2020 at 8:16 PM, vinyvince said:
Did i miss something , or just non compatible with 17.5 or 18?
It still works with Houdini 18.
Make sure to download and extract the rar-file from the initial post. Next dive inside the interiormapping2 shop node and set the color map node to the Atlas01.jpg from the extracted folder.
