Vorkosigan Posted December 19, 2013 Share Posted December 19, 2013 Hi guys, I think I post in the wrong sub cat, sort of. Any way, I recompiled the c++ PRT_Rop for 13.0.266. You can dld the dll here Now, I am pretty new to HOUD, and I don't know how to use the exporter. I plugged a ROP OutputDriver after my Null OUT fluid surface cache and named the thing .prt instead of .geo. Obeviously, did not work, .prt are unusable. Anyone wotj experience of the otl can gove a hint, show me the path to go to export my FLIP to PRT ? Thank you ! Tanguy Quote Link to comment Share on other sites More sharing options...
IvanPulido Posted February 4, 2014 Share Posted February 4, 2014 i am looking for PRT output driver for Houdini 13.0.288, is there someone with these compiled version?, please let me know Quote Link to comment Share on other sites More sharing options...
Vorkosigan Posted February 6, 2014 Author Share Posted February 6, 2014 Hey Ivan, sure. I did not recompiled it for 288 but for 266 and I use it in 288 without any problem. I don't think the lib used in the ROP changed much or not at all. here it is: PRT_Rop_266 Cheers, Tang 1 Quote Link to comment Share on other sites More sharing options...
XRM Posted February 6, 2014 Share Posted February 6, 2014 hey Ivan, you are here! Oh so good to know mate Quote Link to comment Share on other sites More sharing options...
XRM Posted February 8, 2014 Share Posted February 8, 2014 Hey Vorkosigan, Have you solved your problem regarding PRT ? Quote Link to comment Share on other sites More sharing options...
Vorkosigan Posted February 8, 2014 Author Share Posted February 8, 2014 Indeed I am sharing it... Cheers Quote Link to comment Share on other sites More sharing options...
Tom Posted February 10, 2014 Share Posted February 10, 2014 (edited) THANKS! Vorkosigan. Its workng fine for me. Houdini build 13.314 (i didnt use latest daily build because i had some other problems with it) and Krakatoa 2.3.0.54606 For those who this isnt working, you just have to create PRT_ROPDriver node in ROP network. Changing .bgeo to .prt wont work on default rop nodes. And if its still not working, then download VC9 compiled houdini builds instead of VC11. Edited February 10, 2014 by Tom Quote Link to comment Share on other sites More sharing options...
Vorkosigan Posted February 10, 2014 Author Share Posted February 10, 2014 Yep tom is right, i forgot to specify that, it is a VC9 compil. otherwise, pretty straight forward, within a ROP_driver node, load the PRT_rop one and you are almost done. Choose your fluid node and render. It is quite fast though. I can recompiled for other version, more or less. Bit the 266 works fine on all the recent one. Cheers Quote Link to comment Share on other sites More sharing options...
thestuntman Posted February 13, 2014 Share Posted February 13, 2014 Hopefully someone familiar with the Maya version of Krakatoa sees this. I know it's probably not the right forum but it's still on topic in a way How can we use the attributes that are exported with the PRT files with Krakatoa MY? I am mainly interested in Vorticity. It should be getting exported correctly as the PRT ROP picks it up automatically as a value to export along with pscale and all the other usual attributes. Krakatoa MY, I am unable to find any way to use that Vorticity value. In Max, it was easy, as the Vorticity value was able to be chosen direclty as an Input channel, but i have not been able to find it anywhere in the Maya version Quote Link to comment Share on other sites More sharing options...
thestuntman Posted February 13, 2014 Share Posted February 13, 2014 I received this from Thinkbox Software. I loaded the file in a KMX PRT Loader and took a look at its channels. It appears to contain only Position and Velocity and nothing else. Obviously, your exporter did not write the Vorticity out, but it would be difficult to tell why as we don't have our own Houdini exporter at this time. This one does not appear to be based on the exporter code we posted recently on GitHub since it is only PRT 1.0 specification (no metadata for scale and axis orientation). Our latest libraries should support the PRT 1.1 spec.Can you tell us more about the PRT exporter you used? I have tried compiling their exporter at https://github.com/ThinkboxSoftware/HoudiniPRTExporter but I am unable to get OpenEXR to compile, let alone the plugin. Quote Link to comment Share on other sites More sharing options...
edgem Posted September 24, 2014 Share Posted September 24, 2014 Hello; Can someone reupload the exporter Krakatoa for Houdini 13 please? The link above does not seem to work anymore.. Would be greatly appreciated Thanks 1 Quote Link to comment Share on other sites More sharing options...
Horosh3D Posted February 10, 2015 Share Posted February 10, 2015 (edited) I think many would be helpful. Recent compiled version you can download here, as well has its own branch Githu Houdini 13.0.547: PRTRop_13.0.547.rar Houdini 13.0.582: PRTRop_13.0.547.rar Houdini 14.0.201.13: PRTRop_14.0.201.13.rar site just a quick tutorial on the use of (I had trouble so I write): PRTRop_Release_14.0.201.13.dll copy a folder C:\Program Files\Side Effects Software\Houdini 14.0.201.13\houdini\dso in Network panel go to the out and there you will find the PRT_export driver I hope this helps someone because 2 days I suffer with this issue) Edited February 10, 2015 by Horosh3D 3 Quote Link to comment Share on other sites More sharing options...
