daehuck Posted January 2, 2014 Share Posted January 2, 2014 (edited) Hi guys im doing stick test but my hip file doesn't work. I tried same as example hip file hip file is below any pointattribute or destination field name has changed?? I'm confused... please help!! 3ad_flip is an example file... I think it is an old version...but I don't know what is changed.... stickscale.hipFetching info... 3ak_flip_stickscale_from_geometry.hipncFetching info... Edited January 2, 2014 by daehuck Quote Link to comment Share on other sites More sharing options...
edward Posted January 2, 2014 Share Posted January 2, 2014 I tried to look at this file thinking you meant the "Sticky object" but actually this is a file about doing stick on collision in the FLIP Solver. Quote Link to comment Share on other sites More sharing options...
anim Posted January 2, 2014 Share Posted January 2, 2014 in your stickscale.hip go to flipsolver1/Volume Motion/Collisions and enable Control Field then either enter stickscale to Control Field (for your case) or just make sure that you enter the name of the field that will control the stickiness Quote Link to comment Share on other sites More sharing options...
daehuck Posted January 3, 2014 Author Share Posted January 3, 2014 On 1/2/2014 at 4:35 PM, edward said: I tried to look at this file thinking you meant the "Sticky object" but actually this is a file about doing stick on collision in the FLIP Solver. yeah... you're right my subject may be wrong.. Quote Link to comment Share on other sites More sharing options...
daehuck Posted January 3, 2014 Author Share Posted January 3, 2014 On 1/2/2014 at 4:46 PM, anim said: in your stickscale.hip go to flipsolver1/Volume Motion/Collisions and enable Control Field then either enter stickscale to Control Field (for your case) or just make sure that you enter the name of the field that will control the stickiness oh... It works!!!! Thanks for your kindness!! Quote Link to comment Share on other sites More sharing options...
