h13 deep exr 2.0 to nuke8
rendered a dcm .exr from h13. However, the .exr is black in nuke8v1. In mplay, the .exr is not black.
In nuke8, the DeepSample node could display sample data.
Using iinfo dcm.exr, the WorldToCamera and WorldToNDC matrices are all zero. Is it a bug?
File: ./dcm.exr (OpenEXR format)
Resolution: 1920 x 1080
Pz:
Data: 32 bit float
Color Model: Single Channel
Channel Depth: 32 x 1 (32 bpp)
Of (r,g,B):
Data: 16 bit float
Color Model: RGB
Channel Depth: 16 x 3 (48 bpp)
C (r,g,B):
Data: 16 bit float
Color Model: RGB
A:
Data: 16 bit float
Channel Depth: 16 x 1 (16 bpp)
Depth-Complexity:
Data: 16 bit integer
Format Specific Information:
Image Type: Deep
Compression: zips
Comment: none
Created: 2014:01:29 17:37:13
Depth Interpolation: discrete
Samples Composited: true
WorldToCamera: [ 0, 0, 0, 0,
0, 0, 0, 0,
0, 0, 0, 0,
0, 0, 0, 0]
WorldToNDC: [ 0, 0, 0, 0,
0, 0, 0, 0,
0, 0, 0, 0,
0, 0, 0, 0]
You just need to move the deep.back buffer into the deep.front ( or reverse, i m not front of my computer) with the nuke node deep expression.
Have fun
Can you paste the Nuke node here, that would be most useful. Thanks!
  • 10 months later...
