Glue Adjacent with packed Objects
Follyx
I have following problem: a polygonprimtive i.e. a cube, a shatter, a RBD fracture as fractured object and finally a glue adjacent node. Everythings working fine. But if I use a RBD packed object in the rigid body fractur object, I'm not able to use the glue adjacent. It will not glue together.
What in hell I#m doing wrong? Downloaded the masterclass "bullet H13" from SFX and there is a lesson wich shows exactly that what I cannot figure out. So it must work.
Any Ideas and thanks in advance
cheers
