How to fracture hollow objects?
magneto
Hi magneto,
Well I did fabricate a scene based on your snapshot.
I had no issue , could you put up the scene of your snap shot, to see how you are getting this issue.
Here is the hip with the method of the snap that has no issue. Well it is the basic way that you fracture things.
cheers
Mangi
post-2848-0-00491700-1393489690_thumb.jp
fracture_hollow.hipnc
Thanks mangi, I attached my file. I really don't know how mine is different other than I used NURBS and then converted to polygons.
Take a look at the edge that your Fillet SOP is creating. It looks like it lines up fine as nurbs, but when you convert to Poly you clearly see that it doesn't. The Fuse SOP then won't connect all the points and voilá your geo is wide open.
