Render dependencies bug?
Hi bunch,
could anybody confirm me that there´s something fishy going on with Render depencies before I submit to SESI?
I add two nodes to a Merge ROP and then tell the Merge to go "Node by node" (as opposed to frame by frame) and it still goes frame by frame?
Here is a simple sample scene, if you wanna try out yourself..Just change the output folders to wherever fancies you...
RenderDependencies.hipnc
Edited by Netvudu
I haven't looked at your scene, but from memory I don't think it remembers that setting. You have to start Rendering from that window after you have set it to Node by node, not close it and render later. If you understand what I mean.
