magneto Posted April 12, 2014 Share Posted April 12, 2014 Hi, I notice the displaced geometry has jagginess. I am just using basic displacement in a shader but is there a setting that controls the resolution Mantra uses to displace geometry? I tried the Polygons as Subdivisions options on the geometry but they don't seem to stack together. Also for some strange reason, 10x10 divisions grid renders faster than 2x2 grid, so not sure what exactly is happening or how to solve this. I am basically looking very smooth NURBS like detail if possible. Here is the render: Thanks Quote Link to comment Share on other sites More sharing options...
eetu Posted April 12, 2014 Share Posted April 12, 2014 Increase your dicing at OBJ Node -> Render -> Dicing -> Shading quality. Try 2.0 perhaps. 1 Quote Link to comment Share on other sites More sharing options...
eetu Posted April 12, 2014 Share Posted April 12, 2014 You could also try adding the Re-DIce Displacement rendering parameter for the object and switching it on. 1 Quote Link to comment Share on other sites More sharing options...
magneto Posted April 12, 2014 Author Share Posted April 12, 2014 Thanks Eetu for the super fast reply, I just tried them and the rendering turned out silky smooth Although I noticed the memory usage of Mantra seems to increase exponentially with Shading Quality. Mantra got 4GB for a grid when Shading Quality was 2. At 3, it ran out of memory so not sure how much more it would require. Which made me wonder if there is a CVEX Volume Procedural like displacement in Mantra where it doesn't allocate all memory at once but adaptively and still render at "infinite" resolution? Quote Link to comment Share on other sites More sharing options...
eetu Posted April 12, 2014 Share Posted April 12, 2014 Yeah, with shading quality at the default 1.0, mantra dices the geometry at an approximate rate of one micropolygon per output pixel. With 2.0, it creates 4 micropolygons per pixel and so on - so you can guess where that exponential behaviour is coming from You could try playing with the other dicing options, z-importance, flatness and so on, to keep the amount of created micropolys in check. 1 Quote Link to comment Share on other sites More sharing options...
magneto Posted April 12, 2014 Author Share Posted April 12, 2014 Thanks alot Eetu, really appreciate your help Quote Link to comment Share on other sites More sharing options...
