promote nod
if you just want to gather parameters on some node, like null, just edit it's parameter interface (gear menu)
uncheck Prefix Linked Parameter Name and Label checkboxes and Forbid Linking Parameters... checkbox from another gear menu within the Edit Parameter Interface window
then just drag and drop parameters from other nodes to this window, or just choose the ones you like from From Nodes section
http://www.sidefx.com/docs/houdini13.0/ref/windows/edit_parameter_interface
Edited by anim
