wateryfield Posted April 25, 2014 Share Posted April 25, 2014 (edited) I confused is it a right way to describe this question. I have some spheres turn to RBD object .When it falls down, the sphere will come to smaller. It is simple to do this use sop Solver. But the sphere transform smaller all the same as each other. If i want to do a unequal transform, how to ? Is it possible to do this stuff use 'stamp' expression function in sop solver. such as `stamps("../dop", "OBJID", 1)` I have try this, but failed. And is it a way to do the RBD packed object scale by sop solver. It seems i can not dop import the packed object each. Any help will be appreciation. Thanks! sopSolver_stamp.hip Edited April 25, 2014 by wateryfield Quote Link to comment Share on other sites More sharing options...
willow wafflebeard Posted June 3, 2014 Share Posted June 3, 2014 here unequal scale. i dont know if its just me but the default dop import geometry seems to cause me problems so i use an object merge instead. sopSolver_stamp_random size.hip 1 Quote Link to comment Share on other sites More sharing options...
wateryfield Posted June 3, 2014 Author Share Posted June 3, 2014 (edited) here unequal scale. i dont know if its just me but the default dop import geometry seems to cause me problems so i use an object merge instead. Thanks, man. It just works what i want. However can you explain little about ../../.:`stamps("..", "OBJNAME", "NONE")`/Geometry at boject merge. I konw little about this context. Edited June 3, 2014 by wateryfield Quote Link to comment Share on other sites More sharing options...
