Wire solver
thekorsar
Try slow down the speed.
Second increase the sub steps of the dop network or solver step.
The static object for collision you need be sure to right mode. see the bullet data, show guide geometry ,set geometry represention choose concave will be right.
Also wire collision
Some wire object material parameter i set to default, you can adjust yourself.
It still some problems need to fix.
test_wire_fix.hipFetching info...
Edited by wateryfield
wateryfield  thanx a lot, you really helped me)
and one more question, how can i make a spring constraint not in start but in the middle of sequence, when wire touchs the target object,in my example - when the end of the rope touchs object ,it sticks
tried to animate spirng and pinconstraint but it doesnts work(
