3__ Posted July 10, 2004 Share Posted July 10, 2004 is there a quick way I can display node output values in vops? also would it be possible in theory to have this information available via middle-click-info over node connections? -cpb Quote Link to comment Share on other sites More sharing options...
edward Posted July 11, 2004 Share Posted July 11, 2004 There's only a limited number of cases where this can possibly work though. Quote Link to comment Share on other sites More sharing options...
3__ Posted July 11, 2004 Author Share Posted July 11, 2004 uh, yep. posted too soon. you'd have to specify which point is being monitored. perhaps the first one by default. -cpb Quote Link to comment Share on other sites More sharing options...
DaJuice Posted July 11, 2004 Share Posted July 11, 2004 Print VOP? Quote Link to comment Share on other sites More sharing options...
Jason Posted July 12, 2004 Share Posted July 12, 2004 Be nice if you could click on the shader-ball and the closest point of the surface could be highlighted - and this point's values would appear in the MMB menus thoughout the tree. I'm pretty sure that this would be tricky to implement considering that the tree is not cooked node-by-node at run-time as with SOPs, etc. Code is generated from the entire tree, then it's compiled and then fed into the VEX interpreter. When MMB is depressed, I guess the single point would need to be rendered and some pretty specialized code would be needed to generated to cause the interpreter to spit out ALL the variables in the right places, ready to be caught by Houdini and displayed. That being said, I've also wanted a feature like this often - it could be really useful. I can imagine dragging the "selected point" handle around the surface and analysing the result on the fly. In the "Extended Info.." it'd be nice to see the generated code snippet, maybe with the variables substituted, etc... but I'm dreaming here... Quote Link to comment Share on other sites More sharing options...
TheUsualAlex Posted July 12, 2004 Share Posted July 12, 2004 Jason said: Be nice if you could click on the shader-ball and the closest point of the surface could be highlighted - and this point's values would appear in the MMB menus thoughout the tree. Oh how I wish for that! Quote Link to comment Share on other sites More sharing options...
