Convert - Reverse - Flip Backslash \ to a Forwardslash / hscript
LaidlawFX
Hello,
I'm using Hscript for some paths in Houdini and some of the global variables on windows are coming in as Backslashes \ and for some uses I need them as Forwardslashes / in Houdini and \ backslashes outside of Houdini.
Is there a way to change the forward slash to a back slash? Unfortunately backslash is an escape character...
http://www.sidefx.com/docs/houdini13.0/commands/_guide#idm47064707811440
Example
C:\Windows
needs to be
C:/Windows
As silly as this is in order to convert the other way this is the method i have, but doesn't work in the reverse
`strreplace(strreplace("C:\Windows","/","\ ")," ","")`
Thanks
-Ben
Edit: mistyped forward instead of back
Edited by LaidlawFX
For forward to backward slash is this conversion a bit simplier:
echo `strreplace("/project/project.hip", "/", "\\")`
For other direction I'm more comfortable with python:
echo `pythonexprs("str('c:\project\project.hip').replace('\\','/')")`
Hey Petr,
Thanks for the help, one last question for this then, if you don't mind.
Would you know why something like this wouldn't evaluate?
echo `pythonexprs("str(expandString('chs("mypath")')).replace('\\','/')")`
with chs("mypath") == c:\project\project.hip
I'm at the unfortunate situation to be half between languages at this point.
Thanks again
You are welcome, for python it needs to be:
hou.expandString('`chs("mypath")`')
(hou is Houdini python module, and there are extra backticks around chs())
But this hscript(python(hscript)) seems to be a little bit complicated for evaluation.
Once in python stay in python:
echo `pythonexprs("str(hou.parm('/obj/geo1/null1/mypath').eval()).replace('\\','/')")`
Where mypath is string parameter on the null1 node.
For evaluating on the same node you can use something like this in hscript expression:
`(pythonexprs("str(hou.pwd().parm('mypath').eval()).replace('\\','/')"))`
Where pwd() return current node.
python_hscript.hip
Guest mantragora
Remember that you can also use
>>> import os
>>> os.path.normpath("C:\\\Windows/System32//oobe\/\/\/info\\\\//////backgounds")
'C:\\Windows\\System32\\oobe\\info\\backgrounds'
to fix mixed slashes problem and always get "\\" from environment variables or any path. Edited by mantragora
