rendertime_params
3__
I'm wondering if there's a way to set rendertime
parameters for sops, namely subdivide divisions
(Eg: current: 1, Render: 3).
this is to avoid having to manually toggle bypass
on various sibdivides in an object before rendering.
-cpb
does this post from Jason help?
I'd consider using a Houdini variable. $SUBDIV_LEVEL or something. You can easily also add aliases to increasing and decreasing this too.
In the Textport:
Director ->  alias low   set subdiv=0
Director ->  alias med   set subdiv=1
Director ->  alias high   set subdiv=2
Director ->  med
Director ->  echo $subdiv
1
Director ->  high
2
Hope this helps,
Jason
setting a variable and opparm commands are both
working, but I want to have it apply only at render-time,
preferably without creating any file/system dependencies
that prevent moving the hipfile around.
-cpb
special subdivide sops... ?
Howabout something more generic:
Script fields (not just script-file fields) for pre/post render scripts.
A render option (drop-down list?) to switch to a take at rendertime.
-cpb
yea, you don't need to make an external file to script something this easy.. just put it right there in your rop...
here, i made an example file for you.. i made a variable called SUBDIV in the alias/variable pane (Alt-A).. i set my subdiv param in my subdivide sop to $SUBDIV.. then go check out my rop and under the scripts tab..
for pre-render i have:
set -g SUBDIV = 3; varchange
for post-render i have:
set -g SUBDIV = 0; varchange
You don't need the -g unless you are dealing with variables made in the alias/variable pane. since mine was, i used the -g (meaning force global variable)...
the varchange is there to recook my sops that use variables.. from the docs:
When a variable value changes, the OPs which reference that variable are not automatically cooked. Running the varchange command causes all OPs which use a variable that has changed to be re-cooked.
if i didn't recook them, you would never see your subdivide update during or after render.
hth,
dave
http://studentpages.scad.edu/~dquiru20/ren...endersubdiv.hip
What I meant was you just have a different subdivide sop for rendering. Let's say you have two levels of detail, a level 1 subd for display purposes and then a level 3 for rendering.
Then it's done trivially as:
- One subdivide that is level 1. Set the display flag on this
- Append to it, another subdivide. Set this to level 2. With the previous subdivide, the geometry is subdivided 3 levels. Set the render flag on this.
excellent, thanks everyone.
I had tried it without varchange but now it works.
also it seems the variables have some odd case-sensitivity;
setting them can be done in lowercase via textport but they
must be in uppercase in the rop. a bug?
-cpb
lowercase should be fine in textport, variable pane, sop parameter, and rop.. you can even have two different case sensitive variables at the same time..
i.e. i can add 'subdiv' to my variables along with 'SUBDIV' and everything will recognize them as two seperate variables..
