3D poisson surfacing of pointclouds
freaq
has anyone attempted to do this in Houdini or other 3D surfacing algorithms?
can anyone speak to the feasability of this? I'm thinking of attempting it, but could use some pointers as this is quite complicated and I have very little experience (basically none) with surfacing...
Greets freek
You can get something that looks like poisson by just scattering very dense point cloud then fusing points within a radius (with fuse sop, set to keep unused poitns).
sort of OT: I really wish hair/fur used poisson for its scattering, because we normally have increase fur density a lot to compensate for the gaps/holes visible in the scalp caused by the regular random distribution...
  • 2 weeks later...
if it's exactly that (more or less planar projection surface)
then you can just save rest position
do Triangulate2D
and copy rest back to P to get the same result
for objects with cavities though, it's much more difficult
  • 2 weeks later...
well the example actually shows some overhangs in that model,
the delauney triangulation 2D triangulate would not be able to handle that pointcloud I'm afraid.
I have considered, "smoothing my pointcloud" to something that could be mapped as a 2D manifold when storing positions, then Triangulate and then replace,
but overlaps and tehrefore non manifold geometry are just not solvable that way. I could do almost like a UV unwrap, but it would be painful.
Edited by freaq
I mean look at this for example:
this would be incredibly usefull in Houdini
I wonder whether it would be possible as Meshtools are opensoucre to potentially integrate this into a sop...
I lack the knowledge to do so unfortunately.
I'm surprised that no one has yet mentioned to just run the command line meshlab from a Unix SOP since it can read/write .ply files. So you can easily just have a command that converts to ply, run through meshlab, convert back to bgeo.
 see that would be perfect, I was thinking of going through the sourcecode or something... or creating my own, but just seemed so hard and complex...
I might give that a try thank you!
and Jason if you ever do give that a try let me know please! :D
the problem with VDB is that it does not use the actual points but rather envelops,
one could do some smart tricks there, but basically you always have 2 surfaces instead of one.
and the surface s away from the border, and is susceptible to holes...
Edited by freaq
