muzaffer Posted July 1, 2014 Share Posted July 1, 2014 Hi All, How to active viscosity only inside a box or sphere. Outside of box should be 0 or some numbers. Thank you Quote Link to comment Share on other sites More sharing options...
eetu Posted July 2, 2014 Share Posted July 2, 2014 Check if this thread helps: http://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&t=31187&highlight= Quote Link to comment Share on other sites More sharing options...
muzaffer Posted July 2, 2014 Author Share Posted July 2, 2014 Thank you eetu, I have checked two of hip files, but doesn't answer my problem. I want to get slow down when fluid inside the box or sphere, if fluid reach to out of box or sphere border want them to turn actual 0 viscosity. hope this is more clear for who want to answer, Thanks again Quote Link to comment Share on other sites More sharing options...
eetu Posted July 2, 2014 Share Posted July 2, 2014 (edited) Ah, in that case you need to move the test into a SOP Solver DOP inside your simulation, so that it is performed every frame. ee_bounding_viscosity_sdf_sopsolver.hip Edited July 2, 2014 by eetu 1 Quote Link to comment Share on other sites More sharing options...
muzaffer Posted July 2, 2014 Author Share Posted July 2, 2014 you are awesome eetu, really thanks Quote Link to comment Share on other sites More sharing options...
felipon Posted September 11, 2014 Share Posted September 11, 2014 Thanks Ah, in that case you need to move the test into a SOP Solver DOP inside your simulation, so that it is performed every frame. Thanks!!! Quote Link to comment Share on other sites More sharing options...
