This should be extremely simple (as it would be in Maya), but I can't figure out how to parent constrain one object to another but only constraint certain axes, i.e. the x and z but not the y.
I need to constrain something to an fbx with animation so I was using a rivet but I can't see many controls.. In Maya I could create a point constraint (which seems to be the equivalent of a rivet) and select the axes.
Surely this is simple in Houdini?
Cheers,
Mike
Cheers,
Mike
Put down a blend node after the rivet/sticky/fetch/parent and uncheck the channels you want to exclude.
