PaulM3D Posted July 18, 2014 Share Posted July 18, 2014 (edited) Hi guys! I've got a plea for someone, who know about Houdini Mantra Multiple Image Planes(PBR) - could you PLEASE give me a scene(.hip file) with simple pbr-compatible shader, 2 light sources - direct and indirect, and mantra rop, which produces this passes: 1. direct irradiance - amount of direct light received, could be black&white(float). it must be only amount of light, without enything else; 2. diffuse - without shading, only color(i know, how to reach that one); 3. indirect - AMOUNT of indirect light received, as in "direct irradience" pass; 4. specular - i want simple specular, without diffuse and anything else. couldn't reach it by myself. I've got diffuse component in my tests. 5. reflection - i think, it's like "inderect_reflect" from mantra surface shader default image planes. But I don't need diffuse! Only reflection of objects and self-reflection - no lights. Terminology, that I'm using - it's from MentalRay. I want to reproduce my Mental Ray(from maya) shader in Houdini Mantra, but I just can't get those freaking passes! I want to say - I'm not lazy bastard. I've wasted a lot of hours, trying all default image planes, trying to create my custom export nodes in vex editor - I simple can't understand it! I will not give you my failed .hip files because there is not any usefull information. I will attach file with test shader and passes that I need to achieve from Mental Ray. Crying for your help. I will be much MUCH appreciate it. I just need scene, that is got shader and rop, that gives result that I need to dive in, explore it and understand, how it works... Best regards, Paul. Edited July 18, 2014 by PaulM3D Quote Link to comment Share on other sites More sharing options...
xray Posted August 11, 2014 Share Posted August 11, 2014 Have a look at the "properties" -> "output" tab in the Mantra ROP. There's a parameter called "Extra Image Planes". set it to 5 (the number of additional AOV's you want). This will turn on a parameter block for each AOV. Next to the parm "vex variable" in each parameter block, you should see a little triangle. This is a pulldown menu of presets. You can find direct/indirect diffuse, reflect, refract, etc. here. Hope that helps. Quote Link to comment Share on other sites More sharing options...
jordibares Posted August 11, 2014 Share Posted August 11, 2014 Hiya Paul… have a look at this guide http://www.sidefx.com/images/stories/tutorials/user_tutorials/jordi_bares/houdiniguides_chapter2_shading.pdf Page 205 onwards.. I highly recommend you download all the book's chapters http://www.sidefx.com/index.php?option=com_content&task=view&id=2711&Itemid=166 Hope it helps jb 1 Quote Link to comment Share on other sites More sharing options...
PaulM3D Posted August 12, 2014 Author Share Posted August 12, 2014 xrayThanks for answer! I have been exprerimenting with Image Planes for a long time and have got needed result. Unfortunately, don't remember it right now and my notes are at work, so I'll post it in this topic later(like 2 weeks). jordibaresThank you very much! I've been searching info like this for a lot of hours and haven't found anything usefull. Quick look on your link - that's what I neen on this stage of my work. Much appreciate! Will download now and dive in. Quote Link to comment Share on other sites More sharing options...
