kleer001 Posted August 5, 2014 Share Posted August 5, 2014 ... and then merge them with another set... ?! I have a mess of presets for SOPs, DOPs, ROPs, POPs, etc at home. And I have a similar, but more extensive set at work. How can I merge these two non-destructively? Or even better how can I share these with coworkers or the nice people here at OdForce? I know I can RMB click on an individual node and "Save to Gallery", but that seems painful to do for dozens of nodes. Heck, I don't even remember which ones have presets. Maybe there's a phython solution. As an aside... if I had only one complaint about Houdini it would be the severe lack of presets and preset libraries. Maybe this burrows down into general dealing with presets lack there of. Or maybe I'm being too demanding and complainy. Quote Link to comment Share on other sites More sharing options...
Skybar Posted August 5, 2014 Share Posted August 5, 2014 They're saved as a file in the preferences, aren't they? Maybe you could do something with those. Quote Link to comment Share on other sites More sharing options...
kleer001 Posted August 6, 2014 Author Share Posted August 6, 2014 (edited) yup, they're all saved in: Users\Documents\houdini13.0\presets\ as an "idx" file. There's this thread that makes the whole process seem 100x more painful than it needs to be: http://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&p=119112&sid=6ebd26ef7721b8f1a29b3e22572bcf57 then there's this method from an old co-worker: http://www.subsites.org/408.0.html Quote 1) expand your local presets in (eg. in $HOME/houdini9.1/Presets do "hidx -x myFilePreset file.idx") this creates a directory myFilePreset with all your File-SOP presets as single files2) expand your show-presets (eg. /job/myjob/common/houdini/presets do " hidx -x showFilePreset file.idx") this creates a directory showFilePreset with all the Presets for that node which are available to the show3) copy the presets files you want to share with the show from your "myFilePreset" directory into the "showFilePreset" directory4) pack your presets back together using "hidx -c "showFilePreset" file.idx, and the same to your presets as well.5) and you are done Maybe I'll try that last one, it doesn't seem too insane. Edited August 6, 2014 by kleer001 Quote Link to comment Share on other sites More sharing options...
kleer001 Posted August 9, 2014 Author Share Posted August 9, 2014 (edited) Ok, tried this out. Notes: 1) "hidx" is not a standalone program on MacOSx, you have to open up "Houdini Shell.terminal" that sister to the Houdini executable in your Applications folder. 2) Second note is that copying the decompressed preference file, in that directory you created, isn't enough. You also have to add the name of the preference in the accompanying "Sections.list" file. Name it twice and separate by a tab. If the preference to add is called "Easy Peasy" you have to add the line "Easy Peasy" "Easy Peasy" Now, all I have to do is roll it up into a mungy python script. Easy as pie! Well, pie that takes a few days to prepare. ~ Pipeline Janitor AWAY! ~ Edited August 9, 2014 by kleer001 Quote Link to comment Share on other sites More sharing options...
