berkhak Posted August 9, 2014 Share Posted August 9, 2014 Hi guys, I couldnt figure out something, need your help. So I want to pre scale individual primitives with foreach sop before generating the voronoi fracturing (it is a wood mesh). The classic work flow, scale it down so can get the splinter look when you scale it back after the fracturing. So I just want to make sure I control pre scale the each individual piece by their longest side. Thats kinda it, I ve been trying to do it with vopsop and attrwrangle but I just couldnt make it work correctly. I would much appreciate some help. Thanks! I was going for this kinda solution. Change the name of the string that I might use to scale, and compare the each axis with each other.. but again if you guys know a better way, Im ready to learn. s@mysizeName = "X"; if ( v@sizeAttr.z > v@sizeAttr.x ||v@sizeAttr.z >v@sizeAttr.y) s@mysizeName = "Z"; else s@mysizeName = s@mysizeName; if (v@sizeAttr.x >v@sizeAttr.y ||v@sizeAttr.x >v@sizeAttr.z) s@mysizeName = "X"; else s@mysizeName = s@mysizeName; if (v@sizeAttr.y >v@sizeAttr.x ||v@sizeAttr.y >v@sizeAttr.z) s@mysizeName = "Y"; else s@mysizeName = s@mysizeName; Quote Link to comment Share on other sites More sharing options...
eetu Posted August 9, 2014 Share Posted August 9, 2014 I don't know about the rest, but I think those comparisons should use && (and) instead of || (or). 1 Quote Link to comment Share on other sites More sharing options...
berkhak Posted August 9, 2014 Author Share Posted August 9, 2014 Thanks a lot, my mistake, cheers. Quote Link to comment Share on other sites More sharing options...
