Christian S Posted August 19, 2014 Share Posted August 19, 2014 Hi, It worked when I started using Houdini 5-6 months ago but now it doesn't. Every time I click on a node Template flag, Houdini doesn't show me the Template. I've tried going in the Display Options > Template Geometries but there is nothing I can change in there that makes the template show. I tried to revert back to OpenGL 2 also, doesn't work. Is there anything that I'm missing? Thx! C Quote Link to comment Share on other sites More sharing options...
kgoossens Posted August 19, 2014 Share Posted August 19, 2014 Have you got the latest gfx drivers installed on your machine? Quote Link to comment Share on other sites More sharing options...
Christian S Posted August 19, 2014 Author Share Posted August 19, 2014 Have you got the latest gfx drivers installed on your machine? Good idea Kim. I just installed v340 (certified drivers) for my Nvidia GeForce 670. I was a few version off. Sadly this didnt fix the issue. Quote Link to comment Share on other sites More sharing options...
fathom Posted August 19, 2014 Share Posted August 19, 2014 find you home prefs directory and rename it. then launch and see if it works better. if it does, then you can figure you've got some setting that's affecting things and you can move your prefs directory back and monkey with settings. if it doesn't help, you can move your prefs dir back and look elsewhere. 1 Quote Link to comment Share on other sites More sharing options...
Christian S Posted August 19, 2014 Author Share Posted August 19, 2014 Thank you Miles. This worked. Not sure what setting was broken honestly... I don't want to spend hours searching. Quote Link to comment Share on other sites More sharing options...
Rahul Girish Posted March 24, 2020 Share Posted March 24, 2020 So I had the same problem and for me the issue was my scene view was locked to object level and not in sync with my network view on my second screen... So 'unpinned' my scene view and it started reacting as it should --.-- Classic! Quote Link to comment Share on other sites More sharing options...
