Why am I not seeing the nodes I flagged as template...
Hi,
It worked when I started using Houdini 5-6 months ago but now it doesn't.
Every time I click on a node Template flag, Houdini doesn't show me the Template. I've tried going in the Display Options > Template Geometries but there is nothing I can change in there that makes the template show. I tried to revert back to OpenGL 2 also, doesn't work.
Is there anything that I'm missing?
Thx!
C
  On 8/19/2014 at 2:28 PM, kgoossens said:
Have you got the latest gfx drivers installed on your machine?
Good idea Kim. I just installed v340 (certified drivers) for my Nvidia GeForce 670. I was a few version off. Sadly this didnt fix the issue.
find you home prefs directory and rename it.  then launch and see if it works better.  if it does, then you can figure you've got some setting that's affecting things and you can move your prefs directory back and monkey with settings.  if it doesn't help, you can move your prefs dir back and look elsewhere.
  • 5 years later...
