wierd copy rotation
Hi, guys.
I get a wired problem when i copy some tubes along a bend curve.
I create the N along the curve by polyframe, so i can match the tubes along the curve, everything work well except the rotation.
I upload two picture, as you can see, the last frame tubes have a different rotation between the  first frame.
The only way i come up with was add a stamp. :mellow:
If somebody can tell me what happen to the copy sop will be great.
Thanks!
post-9982-0-04089100-1410271144_thumb.jp
post-9982-0-56797500-1410271147_thumb.jp
copy_wierd_rotation.hip
A quick fix, on your PolyFrame SOP set the "normal name" to 'up'.
Working great!
Thanks, Skybar.
But what's the different between the tangent name:N and up.
I saw if i add a up vector, even i set the tangent name to N, it still works properly.
Be honest, i still don't know too much about up vector.  :blink:
Edited by wateryfield
