junaid Posted September 19, 2014 Share Posted September 19, 2014 Hello There, I am rendering some millions particles and usually point is rendering as disk, is there a way I can render point as spheres?I can use instance but I wanted to keep my IFD size low, therefore I would prefer delay geometry load. If instance is the only option is there a way I can render Instance Geo and Instance points as Delay Load? Thanks, Junaid Quote Link to comment Share on other sites More sharing options...
eetu Posted September 19, 2014 Share Posted September 19, 2014 Hi Junaid! I think an actual particle system is rendered as spheres by default. The modern POPs return just points, so just convert your points to a particle system with an Add SOP. Quote Link to comment Share on other sites More sharing options...
lukeiamyourfather Posted September 19, 2014 Share Posted September 19, 2014 Another way is to add a Primitive SOP and set the "Particle Type" to "Render as spheres" from the menu. Quote Link to comment Share on other sites More sharing options...
junaid Posted September 30, 2014 Author Share Posted September 30, 2014 Hey eetu and and luke, sorry got carried away with work, yeah figured out that and thanks for point out. Cheers, Junaid Quote Link to comment Share on other sites More sharing options...
