orin32167 Posted November 7, 2014 Share Posted November 7, 2014 (edited) Hi guys, I am studying Peter Quint classes 'DOPs Force 1,2,3' When I tested it after watching, I found Bullet and Packed object doesn't work correctly, I don't know why. Whenever I take small force to geometries by an Uniform Force DOP, some objects or whole objects don't move anymore after 50 frame. Interestingly, all them work fine to the 50 frame. I think this is a complicated problem because I can make them work correctly by using RBD or giving high value of force or setting low density of mass or not using Uniform Force DOP(Gravity DOP works correctly). I want to use Bullet and Packed geometries. What's the problem and how can I solve this? I attatched my Houdini file. Thanks! test.hip Edited November 7, 2014 by orin32167 Quote Link to comment Share on other sites More sharing options...
Skybar Posted November 7, 2014 Share Posted November 7, 2014 It's because they are becoming inactive. On the RBD Packed Object -> Bullet Data, disable 'Enable Sleeping' or alter the thresholds for when the rbds should fall asleep. Quote Link to comment Share on other sites More sharing options...
orin32167 Posted November 11, 2014 Author Share Posted November 11, 2014 It's because they are becoming inactive. On the RBD Packed Object -> Bullet Data, disable 'Enable Sleeping' or alter the thresholds for when the rbds should fall asleep. You are right. Thank you very much~! Quote Link to comment Share on other sites More sharing options...
