[SOLVED] cVex displacement propagated to copies.
Hi
I have a simple volume that is displaced at render time via a cVex shader called in a VEX procedural volume shader.
What I want to do is to copy this volume onto points and keep the rendered displacement.
As far as I understand, I need to save the volume on disk in order to add cVex displacement, the op: syntax can't reference a live geometry from the cVex context. That's fine for a single volume but it becomes a problem as I want to randomly copy a bunch of these volume over points: baking everything again into a mega volume seems a false solution.
My problem is that the procedural shader assigned on the source node is not propagated onto the copies, which makes sense for me, but I was wondering if there was a workaround or any better approach to this situation.
Thanks
copy_vexprocedural1.hipnc
post-10914-0-40512700-1416871726_thumb.p
Edited by iamyog
