hoknamahn Posted September 10, 2004 Share Posted September 10, 2004 BrianK said: There should be an "hdkinstall" in $HT/bin. Run that (even under Linux) to get HDK working. You'll probably need internet conectivity to check out a (free) HDK license which happens automatically when you run hdkinstall.and yes, make sure you have a newer build, I think I needs to be > 173 or 175 for Linux. 13729[/snapback] hdkinstall works fine, but "libLM.so error still here". Quote Link to comment Share on other sites More sharing options...
FrankFirsching Posted September 11, 2004 Share Posted September 11, 2004 I have the same error on my linux box. The great thing of hdkinstall is, that it installs a full HDK-license and after that even previous builds of Houdini could make use of the HDK. So I used version 7.0.171 to run hdkinstall and now I'm compiling plugins with version 7.0.142 until a higher release, that doesn't have a broken HDK, will be published to the apprentice community. Quote Link to comment Share on other sites More sharing options...
ivan Posted October 23, 2004 Share Posted October 23, 2004 so the solution is to use an older version of H7? Quote Link to comment Share on other sites More sharing options...
FrankFirsching Posted October 23, 2004 Share Posted October 23, 2004 Hi Ivan! No, the problem was only with build 7.0.171. Now 7.0.192 is out and the missing libLM.so has been fixed. No need to use an old version. Frank Quote Link to comment Share on other sites More sharing options...
