segamega Posted January 13, 2015 Share Posted January 13, 2015 Hello !I have dynamic curve and i need to wrap (like in maya) ear to this curve. I've tried lattice(points) but it doesnt work in this case, i think because objects have different type, i`ve tried convert SOP to convert curve to polygons but its still doesnt work.May be someone know some other ways to do that ? Thank you. Quote Link to comment Share on other sites More sharing options...
avak Posted January 13, 2015 Share Posted January 13, 2015 I think you could make bones from that curve (from the shelf) then add follow Curve kinematic then append capture geometry the mesh with these new bones. Quote Link to comment Share on other sites More sharing options...
segamega Posted January 14, 2015 Author Share Posted January 14, 2015 (edited) I think you could make bones from that curve (from the shelf) then add follow Curve kinematic then append capture geometry the mesh with these new bones. Thank you. Edited January 14, 2015 by segamega Quote Link to comment Share on other sites More sharing options...
segamega Posted January 14, 2015 Author Share Posted January 14, 2015 (edited) I think you could make bones from that curve (from the shelf) then add follow Curve kinematic then append capture geometry the mesh with these new b By this way i have some problems. When i capture geometry it looks like this http://gyazo.com/9a64f21505f9c718ea3ccd3ac4a6955b 1) so if add some weights it starts to behave really bad when simulating 2) bones behave not like a curve do, i think thats because curve can be scaled and bones can not May be there are some another ways to do this ? Edited January 14, 2015 by segamega Quote Link to comment Share on other sites More sharing options...
edward Posted January 14, 2015 Share Posted January 14, 2015 Try WireCapture/WireDeform. Quote Link to comment Share on other sites More sharing options...
segamega Posted January 14, 2015 Author Share Posted January 14, 2015 (edited) Try WireCapture/WireDeform. I get this problem using this assets http://gyazo.com/aae47cdc53825c50fbed2b4783f10957 Edited January 14, 2015 by segamega Quote Link to comment Share on other sites More sharing options...
saman Posted January 28, 2015 Share Posted January 28, 2015 How long or short are ears of your model?, at least a screen shot of your model could help you better. any way for a normal ear as you don't need too much stretch on them I think bones attached on dynamic curves that avak points to works fine. I attached an example hope it helps. head_dyn_ear2.hip Quote Link to comment Share on other sites More sharing options...
goldleaf Posted February 3, 2015 Share Posted February 3, 2015 Perhaps the new Point Deform might be a good place to try as well? Quote Link to comment Share on other sites More sharing options...
