Randomize a start animation time inside a For Each SOP
ManuelSantiago
Hi Guys,
I'm making an effect where i fracture a geometry into pieces. After that fracture, I use a For Each SOP to access all the pieces created. I animate a mask (with ramp on a VOP SOP) to make those pieces disappear. All of this is done.
The problem now is that i want to make the animation on the For Each Sop start a different time (randomize the start). Is there anyway of achieving this?
Thanks a lot guys!
Hi guys, thanks a lot for your time.
I've already found a solution, it works, but maybe its not the best approach.
My goal was to have an animation inside a for each sop starting at different times. That way pieces wouldn't all fade at the same time.
My solution was to use a Timeshift after the Noise_animation, and then i used an expression randomize the number.
Ltp4Hk5.png?1
Do you guys think its the best solution?!
Thanks
Edited by ManuelSantiago
