variable/attribute help
Think of the nodes as a stream of data that flows one direction like a river. The Point SOP was plugged into the Grid SOP before the Attribute Transfer SOP so it doesn't have the attributes created by that node. If you want access to that attribute then plug the input of the Point SOP to the output of the Attribute Transfer SOP.
