Collecting Cumulative value of a Parameter
7ofDiamonds
- Create a CHOP network
- Reference the channel
- Connect an Area CHOP
- Toggle the export flag
Thanks, that was helpful!
Here's a quick hip, both in OBJland with chops and in SOPland with accumulating a detail attribute inside a Solver.
This example is great! Thanks for including the example with the Solver. I saw that example somewhere else but wasn't sure about how that worked. Your hip file cleared that up. Thanks!
Keep in mind that the solver wont compute the first frame, as by default Solve on creation frame is off.
You can also compute it with wrangles at once:
string param = "/obj/sphere/xform1/ty";
float startframe = 1;
float endframe = 240;
float step = 1;
float fps = 24;
float timestep = 1/fps;
float result = 0;
for(float i=startframe;i<=endframe;i+=step){
    float sample = ch(param,i*timestep);
    result += sample;
@result = result;
To emulate the behaviour of Solver SOP use :
float sample = ch(param,(i-1)*timestep);
