Pyro: start simulation on a different frame
Juzwa
So I want my sim to start at '-20 frame'.
I set DOP Network Start Frame to -20 and Creation Frame od the Smoke Object also to -20.
But the sim does not work properly. There is some calculation because it's very slow. But I can't see anything.
Seem that I didn't set the sim properly. How do I set this properly to start at -20?
hmmmm, my quick test worked fine with that method. What is the result you expect versus the one you are getting? And what do you mean by slow? :D
if time is an issue try this technique:
-sim from the first frame (whatever that is) to the amount you want to preroll (20 frames),
-then save that frame to disk (from the dopnet) as a .sim.
- finally set the "Initial State" path to that .sim file. That will then be used as the first frame.
Cheers!
  • 3 weeks later...
Works fine with frame set to -20.
A better way is to set your shot start frame to 1001 (plenty of room for preroll: 1000 frames)
if you need 20 frames of preroll, change your timeline start frame to 980. 1001 is still the first frame you'll be using.
