Seet to Face In houdini - Create a vertex face normals
Zabander
Hi guys, I met a problem, I sent an asseet from Houdini to Maya, then I saw a problem with the normals, that could be fixed in Maya with the Set to Face Normals, using the Create Vertex face normals in the mode Match face normals, I wonder is there a equivalent node in Houdini that can fix it before creating the asset?
Thanks!
