jon3de Posted March 28, 2015 Share Posted March 28, 2015 Hi, I created a box as a Polygon Mesh in houdini 13. After giving it some axis divisions I want to select only some Verts or Faces. But I really cant select anything what makes sense. When I create a selection frame around the whole object to select all faces,verts or edges it only select some randome faces. Is there a hidden parameter which controls this? I din´t find a solution for that I compared it with the selection in houdini 14 and there everything is working as I would expect it to work. I would appreciate any help. Thank you. kind regards Jonathan Quote Link to comment Share on other sites More sharing options...
jim c Posted March 28, 2015 Share Posted March 28, 2015 I get the same problem,seems like H12 was OK, but then at some point this became an issue in H13. Restarting H usually works. Reloading the scene sometimes helps too. If you can reproduce it with any consistency, it might be worth reporting as a bug. Quote Link to comment Share on other sites More sharing options...
jon3de Posted March 29, 2015 Author Share Posted March 29, 2015 Thanks for your reply. I think I will try reinstall H. Restarting doesn´t work in my case. Maybe it has something to do with the Apprentice Version I´m using. kind regards Jon Quote Link to comment Share on other sites More sharing options...
jim c Posted March 29, 2015 Share Posted March 29, 2015 I don't think re-installing will help, it might though. My suspicion is that this somehow crept in, and it seems like it's only really noticeable with the modeling tools in SOPs, so if you're not modeling with houdini, specifically *interactive* modeling, i.e. not just working in the network view, then you may not notice it. I haven't done much with H14 yet, so hopefully it's no longer an issue. Quote Link to comment Share on other sites More sharing options...
edward Posted March 30, 2015 Share Posted March 30, 2015 It could be a video driver incompatibility. Quote Link to comment Share on other sites More sharing options...
